Come, create memories on Narutoverse Rebirth - the culminating product of the NWN Naruto servers.
HomeFAQSearchMemberlistUsergroupsRegisterLog in
» REBIRTH Devblog #2!
Tue Oct 27, 2015 2:17 pm by DM Sai
» REBIRTH Devblog #1!
Sat Oct 17, 2015 4:11 pm by DM Sai
» Server Status
Sun Aug 09, 2015 6:12 pm by DM Team
» Are there any other naruto servers up at the time?
Sun Jul 19, 2015 7:36 pm by xXMcNinjaXx
» What's been going on? Is the server DEAD?!
Fri May 29, 2015 5:13 pm by (Admin) Asuma
» We need more people
Tue May 19, 2015 2:11 am by xXMcNinjaXx
» The Server is Down Thread
Mon May 11, 2015 12:03 am by DM Deidara
» Server Exodus
Sat May 09, 2015 8:18 am by DM Rock Lee
» Akarui Yuki
Sun Apr 26, 2015 7:52 pm by Sasori
Server Status
Sat Feb 21, 2015 9:49 pm by DM Team
~ Server Status ~
OFFLINE (WIP)
Comments: 1
Suiton Update
Mon Apr 20, 2015 3:53 am by (Admin) Asuma
The Suiton Jutsu list has undergone several changes, please be sure to update your jutsu in your bio, and to replace jutsu that have been removed with jutsu of equivalent rank.
Comments: 0
Katon & Elementless Update
Wed Apr 08, 2015 11:05 pm by (Admin) Asuma
The Katon and Elementless jutsu lists have undergone several changes, and we ask that everyone update the jutsu lists on their bios to the new versions.
Thank you,
The DM Team
Comments: 0
Raiton Update
Mon Apr 06, 2015 2:31 am by DM Team
Serverwide Raiton Jutsu list has been updated. Please adjust your bio's accordingly.
Sincerely, DM Team.
Comments: 0
Server Direct Connect
Sat Feb 14, 2015 3:42 pm by DM Team
If you cannot find the server on the NWN list here is the Direct Connect IP:
72.130.188.207:5121
Comments: 1
 Turn Order System
Go down
(Admin) Asuma
Human Resources
Human Resources
PostSubject: Turn Order System   Fri Mar 06, 2015 2:14 pm
Turn Order
Round Start
Your Turn
Regen
DOT Effects
Stun/Hold/Genjutsu Resist Attempt
Free Action
Attack Declaration
Opponent's Defense Declaration
Outcome Effect
Outcome Triggers
Turn Resource Deduction
Pass Turn
Their Turn
Free Action
Opponent's Attack Declaration
Free Action
Defense Declaration
Outcome Effect
Outcome Triggers
Pass Turn
End Round
Definitions:
Round Start: The round begins at the beginning of the turn of the person who had the highest initiative. Even if the person is incapable of taking their turn, the round start remains the same for as long as that person remains in the fight. Should they leave the fight, round start defaults at the beginning of the next highest initiative's turn, but any free actions used during the original round count on the highest initiative's turn are sill counted for the first round of the new round order.
Regen: Standard HP/CP regen that occurs each turn on your turn unless an effect says otherwise.
DOT Effects: Standard DOT such as bleed damage or burn damage, as well as cp drain.
Stun/Hold/Genjutsu Resist Attempt: You get one opportunity (unless an effect states otherwise) to break a stun/hold/genjutsu effect. If you succeed the break, you get the rest of your turn as normal. This does not count as a free action.
Free Action: During the round order, you are allotted ONE free action that may be taken at any of the times listed above. E.g. - If you use a free action to buff an attack on your turn, you may not use a free action defense for the duration of the round.
Attack Declaration: During this time, the player must emote their progressive action AND state the name of said technique. If asked, the player must state the FULL pvp effect of the technique (recommend copy/paste) including special notes. Failure to comply will result in the turn spent as inaction, and loss of the remainder of the player's turn.
Attack: An attack is a technique that targets an opponent, regardless of effect.
Buff: A buff is a technique that targets an ally, or the user of the technique. Performing a buff does not prompt a defensive action unless it would normally used as an offensive technique.
Defense Declaration: During this time, the player must emote their reactive action AND state the name of said technique. If asked, the player must state the FULL pvp effect of the technique (recommend copy/paste) including special notes. Failure to comply will result in the turn spent as inaction, and loss of the remainder of the player's turn. If inaction is taken by default, the reactive player takes progressive player's attack in full.
Defense: A defense is a standard block or dodge, or a defensive technique.
Counter: A Counter is an offensive action that is used as an alternative to a Defense, and doing so costs your following Attack Declaration. (*See rules on Countering.) If a Counter attempt is used, the remainder of your standard turn still goes in its standard turn order (I.E. - your regen would trigger at the same time as normal).
Outcome Effect: The player or players who succeeded in their Attack or Defense Declaration would apply pvp effects such as damage rolls, inflicted negatives, healing, etc. during this time.
Outcome Triggers: Any effects that are triggered based on damage dealt, a successful attack, or a successful defense are applied at this time.
Turn Resource Reduction: Throughout each turn, spent resources are tallied up until this time, when they are applied. This includes resources spent on free actions, Attack Declaration, Defense Declaration, or any resource-costing outcome triggers. Resource cost reductions are applied to the TOTAL of resources spent rather than each individual instance. (E.g. - Having Flicker active beforehand (1 cp per round), using an offense boosting free action (Ken- 3 cp), and my Attack Declaration (Ken- 7 cp), you spend a total of 11 cp that round. You have -3 cp to Kenjutsu Techniques and -1 cp universally. You would reduce your chakra pool by 7.)
Pass Turn: At this time the turn ends, stun effects that have finished their duration end, and the following player in initiative would begin their own.
Turn Order System
Back to top
» Order of the White Lotus
» Tier System
» Rune Knights Ranking System
» Turn Yourself Into an Anime Character
» Achievement System and Request Thread [OFFICIAL]
Narutoverse Rebirth :: Server Information :: Server Rules-
